I am using the TMPGEnc DVD author 3 with DivX authoring and here is the problem I am running into.
After importing all my sources and trimming them nicely I noticed that the buttons on top for Menu, Simulation, and Output are all greyed out so that I cannot select them.
Why are they greyed out? I want to make a menu if possible and I certainly need to be able to output to make the DVD.
How do I activate them? Thanks!
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
DVD Flick troubleshooting
By pengsm in forum Authoring (DVD)Replies: 2Last Post: 25th Feb 2009, 12:49 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
