From couple of hours small win appears, talking about some memory.... i have no idea what it is? i am pasting the screen shoot, may be you great ppl could help me??
Results 1 to 11 of 11
dewolf, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
The numbers in the message are unusual. They refer to memory but the locations aren't typical of a normal process (program, dll etc). Even more odd is that the two addresses are the same - i.e., the instruction is trying to access itself.
A very likely reason is a buffer overrun. This is often caused by web sites with malware trying to crash your computer in order to control it. What happens is the web site sends a very long string that causes IE to write it into a part of the program that it shouldn't, overwrite the original code.
It can also happen if the web site address is very long (more than 255 characters). In earlier versions of IE, this was a significant bug leading to security problems.
I suggest you take a note of which web sites are causing the problem. -
so maybe trying firefox will help in this case
check this thread for more help
https://forum.videohelp.com/topic334260.html -
Sounds like there might be some sort of malware (virus/spyware/etc.) that's attempting to call out every so often.Originally Posted by dewolfIf cameras add ten pounds, why would people want to eat them?
Iexplore is Internet Explorer
IEXPLORE Application Error may not sound like an easy to understand error message but in fact it's very meaningful:
Internet Explorer is an Error as an Application.
It's shiteware, a dog's breakfast. Should never have been released.
http://getfirefox.com/ -
Most of the sites having same problem... even hotmail.Originally Posted by JohnnyMalaria
I did follow the instruction of MJA's provided link.... but nothing much happen. IE saying me continuously that add ons are disable ( as i did disable it).
32 bit application exe on a 64 bit OS?
By neworldman in forum ComputerReplies: 5Last Post: 13th Sep 2010, 12:30 -
.EXE is not a valid Win32 Application...what to do? :(
By drunkenboxer in forum ComputerReplies: 10Last Post: 27th Feb 2009, 12:51 -
Application Error
By Jmorales27 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 10th Jul 2008, 14:35 -
iexplore.exe - Application Error
By bluemoss in forum ComputerReplies: 9Last Post: 25th Nov 2007, 07:23 -
iexplore.exe running each time I reboot
By alegator in forum ComputerReplies: 16Last Post: 4th Jul 2007, 10:13
