Is there any suggestions what FFDShow version i should use? I have been using rev. 610 (20061201) for a while now, but i have sometimes problems with video (xvid/divx) playback.
Often playback (atleast once) goes either like fast forward for a couple of seconds or then picture freezes (jumpy playback) for a short time, while sound continues normally.
Though i'm not sure if it's a FFDShow issue. I'm thinking to install ffdshow-20051129, because it's said to be a good version. Is that so? Or should i just install latest beta?
Any other ideas what can cause those video playback issues?
	Hi,
 I've had good luck with the latest clsid "stable' builds. A 1.6ghz Duron processor is probably borderline for decoding, especially if you are using any post-production filters. Even realtime volume-normalizing which is enabled by default could rob you of enough resources to playback video.
	Hi GMaq.
 I don't use any post-processing, volume-normalizing or resizing. With xvid/divx videos my player CPU usage moves between around 15-25%.
 Could you give a link to those clsid "stable" builds?
	Should i download that "ffdshow tryouts official beta3 - generic build (stable)"?
 http://sourceforge.net/project/showfiles.php?group_id=173941
	Ok, i just installed it. CPU is still the same, but i have to see, if that playback issue is still present.Originally Posted by j4gg3rr
  Blu-ray backup/playback problems (mkv, m2ts, ffdshow, mkv splitter)By Pyrophoric in forum Video ConversionReplies: 0Last Post: 3rd Mar 2010, 11:26
  FLAC playback with MPC-HC & ffdshowBy mark91 in forum AudioReplies: 3Last Post: 25th Aug 2009, 21:17
  how to enable ffdshow for m2t files playback?By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 28th Jul 2009, 14:33
  VOB playback & ffdshow...how to let them talk ?By fabvideohelp in forum Newbie / General discussionsReplies: 0Last Post: 20th Nov 2007, 08:51
  ffdshow playback and aspect ratioBy greenbag in forum Video ConversionReplies: 6Last Post: 12th Oct 2007, 03:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
