Ok here is what I have done so far and where I want to be next..... I have several home VCR tapes of the kids, I was able to put about 3 hours (6 tapes) onto a DVD yesterday with my home DVD recorder. Now I want to put this video on my pc, so I can edit out the stuff I don't want. I have copied the Video_TS file on my pc, but when I try to open it in Windows Movie Maker I get the above error message. I take it I must change this file somehow, so this can be imported into Windows Movie Maker so I can edit it, then burn a new one on my (soon to be bought internal DVD burner). If I am way off on how to do this, please let me know![]()
Donna/Indiana
"The mother of a disabled child will never take for granted a "spoken word".
She will never consider a "step" ordinary. When her child says "momma" for the first time,
she will be present at a miracle and know it" Erma Bombeck -
Ah! the old accept/expect/except mistake
Should be "won't accept"
If you have TDA, it does a pretty good job of ripping the VOBs to mpg. Just check the "save a copy to disk" option (I think that's what it is called). -
Gerry, thank you so much, I will give it a try,.....
Lost, LOL I can't believe I did that, but if for some reason Gerry's idea does not work I will try yours
Thanks to both of you for the fast responseDonna/Indiana
WMM also does not output MPEG, so you have the choice of DV AVI (Recommended) or WMV. That means you will have to re-encode your video twice to get back to DVD format.
Just my opinion, but you would be better off to use a real MPEG editor such as VideoReDo or MPEG-VCR or one of the all in one editor packages. There's no advantage to re-encoding if you are just doing basic cuts and pastes and you would have much less quality loss.
And welcome to our forums.
How Do I Convert an MP4 file to Windows Movie Maker format?
By gasjkh22 in forum AudioReplies: 7Last Post: 28th Aug 2011, 05:13 -
Restoring capture from Windows Movie Maker .tmp file
By markm96160 in forum Capturing and VCRReplies: 3Last Post: 17th Nov 2008, 14:37 -
Problem with Windows Movie Maker not recognising .avi format
By NP11073 in forum Newbie / General discussionsReplies: 4Last Post: 14th Sep 2008, 06:39 -
Easiest method to rip a DVD to a Windows Movie Maker compatible format
By computer2slow in forum DVD RippingReplies: 6Last Post: 9th Apr 2008, 19:11
