So I have downloaded ffmpegX and am trying to convert .mp4 to .flv on a Mac G5 with osx10.4
The problem is that when I put the desired .mp4 file in, it says that it is unrecognized. I try to encode it, but it just creates a blank document. I think that I have properly installed the extensions necessary, but I could be wrong. Any tips? Or any ideas for an easier way to convert to .flv? Thanks!
~Amber
If the self-installer window does not come up after launching ffmpegX, then the binaries were installed correctly.Originally Posted by amberayoder
Try to get codec information on this file through other means, e.g. VLC (open the Information window, then More Information, then open the streams; it should list the codecs used) or an other player that lists details.Originally Posted by amberayoder
If ffmpeg can't decode the file, but mplayer can (try the Play button), then you could transcode with mencoder first, to make a more compatible file.
Upload source to video sharing site such as YouTube, that convert anything that comes in to flv, then download again.Originally Posted by amberayoder
I am having a similar problem using the ffmpegx software except when i drop andy file in the source format the target format creates and file with multiple extensions i.e. racewrsweb.mov.ff.flv
How can I fix this problem?
Shadow box after converting to Mpeg2/MP4/FLV
By LouieLand in forum Video ConversionReplies: 6Last Post: 1st Feb 2010, 13:11 -
Having problems converting flv to MP4
By Norkusa in forum ffmpegX general discussionReplies: 5Last Post: 16th Aug 2009, 20:54 -
Best way for converting VOB to FLV, AVI, MP4
By lana2000 in forum Video ConversionReplies: 13Last Post: 22nd Feb 2009, 09:56 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Codec type mismatch for converting MP4 to FLV
By swashbuckler75 in forum ffmpegX general discussionReplies: 2Last Post: 24th Apr 2008, 12:28
