I have been using version 2.5 of vob2mpg (with the great command-line support) to convert to MPG and I have noticed recently that certain DVDs (all unprotected) get outputted with either loud static as the sound, or the sound is fine until you play it in Windows Media Player 11 and fast forward (and then you get the static). This doesn't happen with all my DVDs.
I saw this was reported in some postings on this site, however, I did not see any final word on it. Any ideas?
Thanks!
Point One : Windows Media Player is one of the worst players to test anything in, and any results or issues with the playback experience should be treated with caution as they will, in most cases, be down to WMP being a POS. It doesn't even playback flagged 16:9 mpg files at the correct aspect ratio half the time.
That said, AC3 or DTS audio, is played back as raw files (i.e. not decoded) are basically pink noise. It will sound like static, and if you have it up loud enough, will blow your speakers.
Perhaps VOB2MPG is having an issue ripping the audio correctly, or the original audio was flawed, and now WMP is having problems decoding it correctly.
First thing to do is ditch WMP for testing and playback. Try any of the following
Media Player Classic (MPC)
VideoLan Client (VLC)
KMPlayer
and see if the problem persists. If it does, and the audio is AC3, demux it, run it through AC3fix, then mux it back in and listen again.Read my blog here.
Registration Issue VOB2MPG
By spysmily1 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 12th Jan 2011, 13:03 -
VOB2MPG Index out of bounds error when trying to convert some DVDs
By secretsubscriber in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 1st Mar 2010, 09:35 -
VOB2MPG PRO audio sync issue
By wriggley in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 5th Feb 2010, 16:19 -
VOB2MPG and anamorphic DVDs
By Smithcraft in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 18th Aug 2009, 19:50 -
Working with VOB2MPG: speed issue hint
By cdgmol in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 31st Jul 2009, 17:57
