Hi,
I reconverted many 20min videos with H.264 x.264 / AAC and it went all good, but then with the same codecs I converted 2 movies that were 1h40min and the video track became 50min long while the audio track was still 1h40min.
The images look accelerated, I guess some frames have been omitted but I don't understand what happened, I did not change the video parameters after opening the movie in ffmpegX
Attached is the preset I used for the first movie.
batteries%20not%20included.ffx
Try decoding with QT and see if this problem goes away. I've not encountered this before, but apparently others have. Generally speaking, QT seems to handle timing a bit better, so if your transcoding options allow its use, it's probably a good choice. It's worth a try, in any case.
Good luck!
Help with movies on cd's
By deb4tlj in forum Newbie / General discussionsReplies: 10Last Post: 13th Aug 2009, 14:02 -
Best xvid parameters for DV movies conversion
By Boro72 in forum Video ConversionReplies: 1Last Post: 18th Jan 2009, 09:47 -
MPG2 capture bad frm 40min to 50min marks, exclnt qlty before and after?
By tonytbaloney in forum Capturing and VCRReplies: 6Last Post: 5th Feb 2008, 16:57 -
name of a movies
By thebirdf in forum Off topicReplies: 1Last Post: 11th Jan 2008, 10:27 -
Archos for recording TV movies for later conversion into Divx format
By guy1955 in forum Portable VideoReplies: 0Last Post: 23rd Jul 2007, 07:46
