Ok, so basically I've used advice and programs here to create a highlight DVD for sports. I used several programs like VOB2MPG and Mpeg video wizard DVD to create a file that has all the clips I want along with a title and opening. However, when I open the file that has the titles and some transitions and stuff there are about 8 files and there are several big files and several small files that are in "VOB" "BUP" and "IFO" formats with the "VOB" ones being the larger files. On the other hand, when I go to properties of the plain video file without any transitions or extras, it says its a "Movie Clip" and it opens in Windows Media Player. Its 2.88 GB. Ideally, I would like to get the version with titles and stuff onto a DVD but if that would take a lot of work then I would just like to put the basic version on a dvd that will open in any dvd player or computer. I have regular and double layered dvds, so if you could just let me know what I need to know I would really really really appreciate it. Thanks in advance
See "What is DVD" on the left <<<<<<<<<<
The VOB, BUP, IFO files are the DVD file structure, and should be ready for burning to a DVD.
I recommend ImgBurn - as a beginner, it's a pretty easy program to use, but there are a few guides here:
http://forum.imgburn.com/index.php?s=8e6eb41e9034228562ee120faee67e3b&showforum=4
Jim
Beginner Help Burning
By Leedsphan24 in forum Authoring (DVD)Replies: 6Last Post: 15th Apr 2009, 00:56 -
Complete beginner struggling to write DVD - please help!
By robbief in forum Newbie / General discussionsReplies: 2Last Post: 14th Feb 2009, 09:17 -
By robbief in forum Authoring (DVD)Replies: 3Last Post: 14th Feb 2009, 09:04 -
DVD Lab Pro Beginner
By Nerfboy in forum Authoring (DVD)Replies: 5Last Post: 23rd Apr 2008, 18:06 -
some advise for a beginner (VIDEO /DVD)
By nobbydadog in forum Authoring (DVD)Replies: 3Last Post: 8th May 2007, 18:32
