I'm looking mainly for speed, not really that big on quality, as long as it's not horrifyingly bad. Or could someone suggest another format that's equally or more efficient in size?
Results 1 to 9 of 9
The only RV9EHQ encoder is from Real, so any app that you use is going to be using the exact same encoder. AVC I would say is more efficient than RV9EHQ, however I couldn't say if that applies at high speed settings.
Thanks......any other format that's efficient in size that's escaping my mind right now?
why RMVB ? AFAIK very few devices besides a PC will use it ? to most people quality means more than file size.
why compress it and save it if the quality is going to suffer -
Space/size and bandwidth (in terms of transferring over a network), primarily. That's why Real formats initially became popular, IIRC.
If cameras add ten pounds, why would people want to eat them? -
Well I'm gonna be uploading some videos to a community that actually has rules on this, and I have to conform to those rules.Originally Posted by theewizard
Anything else besides RMVB that will make the file size roughly the same? -
WMV does fairly well. Xvid or Divx is more universal. MPEG-1 also, but the file size will generally be larger. You can find more compact formats, but they take a fair amount of computer power and time to encode and decode and are not very universal.
With highly proprietary formats like Real and Quicktime you mostly have to use their encoders with their settings.
What are those 'community rules'? That would make suggesting a format much easier.
Try WinMPG Video Converter
You could try Any Video Converter 2.06. It's free and I'm pretty sure it supports rmvb files. Haven't used it myself though...but seems like a good little program.
Convert rmvb to AVI
By pchan in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 05:09 -
any ways to convert from avi to asf very quickly?
By George2 in forum Newbie / General discussionsReplies: 34Last Post: 20th Apr 2009, 04:02 -
Batch Convert AVI to MOV Quickly
By huttonhenrysfinest in forum MacReplies: 7Last Post: 9th Feb 2009, 21:23 -
rmvb file crashes every program when try to convert, can it be fixed?
By whatsmyname in forum Video ConversionReplies: 11Last Post: 28th Jul 2008, 22:55 -
A New Way To Convert RMVB to AVI
By RMVBMASTAPRO in forum Video ConversionReplies: 2Last Post: 27th May 2007, 18:41
