I get this error message when I try to author a dvd:
Run-time error '75'
Path/ file access error
Does anyone know a solution for that?
Kate: What's the big thing that happens every Monday at one o'clock?
Tom: The dog outside the pub scratches itself...?
Kate: The plane from Broken Hill arrives! -
Have you upgraded to Vista? I have seen that error before related to Vista's UAC. If not, and you are running XP, make sure you have admin privileges.
I have Vista :S
Maybe there's another program I can use?Kate: What's the big thing that happens every Monday at one o'clock?
you can temporarily disable the UAC, and it should allow DVDAuthorGUI to work fine. google 'disable UAC' and you will find plenty of tutorials.
You could also try GFD, or dvdstyler, but I do not know their vista compatability status.
GUI DVD Author Project default setting
By Genevieve in forum Authoring (DVD)Replies: 4Last Post: 29th Apr 2009, 01:10 -
Question about error with Gui For DVD Author
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 27th Nov 2008, 06:38 -
GUI for DVD Author (GFD) 'Freezes'
By olyteddy in forum Authoring (DVD)Replies: 2Last Post: 9th May 2008, 12:09 -
questions about using GUI for DVDauthor to author DVD
By jimdagys in forum Authoring (DVD)Replies: 8Last Post: 2nd Dec 2007, 19:08 -
GUI For DVD Author - A Couple of Questions
By deadwing in forum Authoring (DVD)Replies: 8Last Post: 6th Sep 2007, 01:25
