Hello-
I shot a stage show with my Canon XL1 Video Camera.
Somehow I recoreded it with 16bit Audio. And now the sound is not loud enough.
Any work around?
Thanks so much for your help.
Results 1 to 17 of 17
Just make it louder with a program that does so. Most audio and video editors have such a feature.
You can do it easily enough in VirtualDub.
File -> Open Video File
Video -> Direct Stream Copy
Audio -> Full Processing Mode
Audio -> Volume (adjust as necessary)
File -> Save as AVI
That will increase the gain of the entire audio. There are filter that will dynamically increase the gain so that soft parts will be louder but loud parts will not distort. -
Originally Posted by ozab
Yes, Jagabo - Its still not loud. Here is the original file. 20 sec.
www.shopat360.com/video.avi <RIGHT CLICK ON LINK AND DO SAVE TARGET AS> -
I downloaded your file. It's a type 2 DV AVI. I was able to increase the volume with VirtualDub 1.7.2 exactly as described earlier. I increased it by ~25 dB to get it up to a nominal level.
Type 2 DV AVI files have two copies of the audio. The raw DV data from the camcorder (which contains both audio and video) is saved in the AVI file as a video stream. A second stream contains an additional copy of the audio as an audio stream. I believe VirtualDub only changes this second copy of the audio.
How did you test the volume of the resulting file? Saving the DV AVI back to tape may not include the modified audio. But most media players will play the second copy.
A further problem you'll have is that the audio is so low that its buried down in the ambient noise. So after you increase the volume the background noise will be pretty loud too. But at least you can hear the voice. -
It can be made much louder - here is your audio track, before and after
The problem you will have is the additional hiss sound when you make it louder. You can hear the words, but there is a lot of "ssssssssssssssssssssssssssssssssss" sound. It is noisy. You can reduce the noise with a filter, but it won't be perfect.
Here's only the noise portion of your recording. Removing this will be difficult without creating artifacts.
noise.mp3
Here's the recording put through the Audacity noise reduction plugin. You'll hear the artifacts.
audacity_noise_reduction.mp3
There are better noise reduction programs out there, none of them are free. DiamondCut DC6 is pretty good . Here's the continous noise filter. It sounds better than the audacity one. You can get DC Millenium (the junior product) for $60. http://www.enhancedaudio.com/millennium.htm
There's a limited function demo on this page http://www.diamondcut.de/enpages/download.html
dc6-continuous_noise_reduction.mp3 -
OK, Guys, I think I am now understading.
One more question - I have 3 hour of total video with speaches in between. And, all the speach part is where the audio is very LOW.
Can you tell me how to fix all the speaches and load it in my Pinnacle Studio for editing?
Thanks again everyone. -
I haven't used Pinnacle Studio in a long time but I seem to remember the audio shows up on the timeline and you can adjust the volume in sections by clicking on the volume line to create nodes, then move the nodes up and down to increse or decrease the volume.
No, What I meant was:
I want to fix the audio in Virtual Dub or with DC Millenium.
Should I load the 3 hour AVI file in those sw. and then fix audio and save it again then load it in my editing program?
Loud buzz when outputting audio only
By joelkranz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Mar 2014, 22:12 -
Captured audio is REALLY LOUD
By justin81 in forum Capturing and VCRReplies: 4Last Post: 11th Aug 2009, 07:43 -
GUI for dvdauthor - audio too loud
By mrcoolekin in forum Authoring (DVD)Replies: 6Last Post: 15th Oct 2008, 04:25 -
Canon GL2, XL1, XL1S, or...?
By nopEda in forum Newbie / General discussionsReplies: 7Last Post: 27th Aug 2008, 15:38 -
16bit Audio not Clear :(
By ozab in forum Capturing and VCRReplies: 0Last Post: 31st Jul 2007, 10:51
