I have this problem:
i want to edit a button on my dvd menu but when i move my mouse over it
the button changes (OnMouseOver option).
look at the picture(uploaded).
My question is:
is there a way to undo this mouseover?
can i make this menu only with the black text with no mouseover ability?
thanks in advanced.
I forgot to mention, i use DvdReMakePro 3.5.3
So if there is an easy way to do that using that software it'll be great. -
If you want to remove highlighting (this also disables button function), use 'hide button' command from right-click on button menu.
If you want to keep button function you can change to black both (select/activate) highlight colors in CLUT tab (right-click/edit color).Originally Posted by shay86
There is no "mouse over" function in DVDs. How a menu reacts to a "mouse over" action is down to the software player. It is also a poor way to test playback because it does not emulate in any way the functions of a real DVD player, which of course does not have a mouse.
Read my blog here.
It depends on your goal.
As mentioned, you can hide or delete a button in dvdremake.
If you want to remove the button (example: removed audio tracks), then simply remove/delete it. I believe that the "hide" feature merely stops the button from being highlighted, in case you want a "secret" button.
I could be wrong, as I haven't used it in a while, but I do remember accidentally making non-highlighted buttons.
Remember to keep a dvd-rw handy to test it out on a stand-alone and eliminate coasters. -
Hiding a button also disables its functioning. Deleting does the same but may need navigation adjusment since remaining button numbers can change. In both cases only background image for button remains. For creating a hidden button (without highlighting) in DVDRemake any place in background (free from subpictures remaining after deleting/hiding buttons) can be used and any size of active rectangular set ('add button' command).Originally Posted by Supreme2k
TMPGenc Authoring Works 4 - How do I set the "first button" on a menu?
By silentmachine in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2011, 08:05 -
"Full Screen" button not working properly
By ironjack in forum Newbie / General discussionsReplies: 2Last Post: 14th Aug 2010, 20:20 -
Using DVDLabPro to create a "sound effect" button?
By takearushfan in forum Authoring (DVD)Replies: 7Last Post: 1st Jun 2010, 20:53 -
Question about secret hidden "Back" button in Gui For DVD Author
By jimdagys in forum Authoring (DVD)Replies: 2Last Post: 15th Dec 2008, 04:17 -
Re: making "live" chapter button with windvd creator 2
By tomcat862 in forum Authoring (DVD)Replies: 0Last Post: 28th Feb 2008, 13:13
