I would like to connect my Sony VCR to my computer. Both units have cable connectors and RCA plugs. When I connect the tv cable from the wall to the VCR and then to the computer, it feeds the TV but not the VCR tapes. Should I use the RCA plugs or the cable connectors?
Thanks,
Bill
Mission Viejo CA
	I'm assuming you can see the cable TV going through the VCR but not when you play the tape?
 If you can hook the VCR up to a TV and see the tape playing hooking it up to your computer should produce the same results. If the tapes in question are commercial tapes then they most likely are not viewable because of copy protection. Test with a non-commercial tape such as one you recoreded yourself if that is the case.
  Media CenterBy superc in forum LinuxReplies: 4Last Post: 7th Jan 2011, 20:39
  Can't capture video with Sony Vegas using my HP media centerBy fuzzblaster in forum Capturing and VCRReplies: 3Last Post: 2nd Sep 2010, 10:45
  Complete Computer Lockup - Security Center - I.D. 1800By hech54 in forum ComputerReplies: 34Last Post: 18th Oct 2008, 16:48
  Sharing TV - 1 Vista Media Center Server to Vista Media Center PCBy JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 02:33
  Media Center HelpBy rwheeler in forum Video ConversionReplies: 4Last Post: 25th Jun 2007, 14:06
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
