Ok,
Here is what I have...
800 Duron
256 Meg Ram
20 Gig HD
Win98SE
3dfx VooDooTV 100 PCI TV Card
Virtual Dub
Built in audio on MB
TNT2 32 meg video card
My problem is that I can not get sound when capturing from VDub. I have an audio cable (like the ones that come with a cd unit) that hooks from the tv card to the CD1 input on the mother board.
When I am watching it, I can hear it, but when I try to capture, no sound.
I think VDub is trying to use the line in channel and not the cd channel for the audio.
Can I change the audio source in VDub? Has anyone else had this problem? HELP!!
Thanks in advance.
Shadow
Well i had the same problem. I could hear the audio WHILE capping, but it wasnt in the capped video. I did have the sound on the motherboard too. I tried opening the sounds level window, and made sure the mute box wan't checked, and made sure the level was turned up. I would check all this first. I never did get my sound to capture with V-dub, so i went and got a pci soundcard(soundblaster live), and after that, it worked perfectly!
So be sure to check all of your sound settings, and also check the recording settings in your sound level window. If not, then pick up a pci soundcard, i'd bet money that it will work. I'm not sure that this is your exact problem, but check your audio connections from your tv card and your input on the MB. V-dub seems to be very pickey when it comes to the audio input.
My config:
700 MHZ duron
320 MB ram
20 G HD
40G HD for capping
VIA chipset
windows ME
soundblaster live sound card -
Hi,
Try this
Before initiating a capture in VDub
double click on the spealer icon in UR systems tray
go to options -properties- recording-OK look if the line in is selected if not click and select .
Then close all
and start capture
G luck
timone
hell i have an soundblaster live and i can't hear any sound when using vdub to capture... when using asus live i hear there is sound in vdub, nothing but silence.. and all the sound settings are as they have to be?!?!?!?!?!?
avisynth -> imageSource + sound (4min) = 40 sec video in vDub
By adom in forum Video ConversionReplies: 4Last Post: 22nd Feb 2011, 18:53 -
VDub Problem
By heygurl in forum SubtitleReplies: 8Last Post: 9th Dec 2010, 19:38 -
Best Vdub deinterlacer?
By brassplyer in forum RestorationReplies: 14Last Post: 25th Apr 2010, 22:50 -
VDub Help..!!
By scratchlikeme in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2009, 07:40 -
vdub -> wmv?
By zapster in forum EditingReplies: 10Last Post: 17th May 2008, 21:16
