I have a bunch of mpeg2 compressed avi videos captured with my TV card.
Whenever I edit and export them using Adobe Premiere the quality of videos is complete disaster. They are pixelated, they are lagging etc...
I've heard that Adobe Premiere works best with uncompressed videos so I tried to convert them in VirtualDub using Panasonic DV codec or as uncompressed AVIs. However when I try to export them in Adobe Premiere the quality of video is still really bad.
Does anyone have any suggestion which other DV codec could I use or which settings.
I've been playing with video settings in Adobe Premiere for hours now and nothing really makes much difference.
What export settings are you using? video codec? video bitrate? resolution/frame size?
I've been trying to export videos using Xvid and DivX codecs. I've tried video bitrates between 750 and up to 3000 (didn't really solve the problems), the frame size is 320x240 because I want to upload them to youtube.Originally Posted by Baldrick
Under video settings I've tried using just about every possible settings combinations. In codec settings I left everything alone except of bitrate settings. -
Try convert to Divx or Xvid with Virtualdub and see if it looks better.
If I convert to Xvid in VirtualDub the quality of output video is perfect. I'm hoping I can somehow get the same quality when editing and encoding video in Adobe Premiere.Originally Posted by Baldrick
Exporting from Adobe Premiere Pro not working
By Devilsadvocate in forum EditingReplies: 1Last Post: 29th Mar 2012, 12:04 -
adobe premiere CS5 video exporting issue
By bteamstephen in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2010, 01:55 -
Help with building a video editing workstation using adobe premiere pro C5
By shawn grimmer in forum Newbie / General discussionsReplies: 2Last Post: 7th Oct 2010, 14:00 -
Best COMPRESSED video editing format in Premiere?
By Namie in forum EditingReplies: 8Last Post: 6th Jan 2010, 21:11 -
Adobe Premiere Elements is cutting off the end of video when exporting
By robvs in forum EditingReplies: 0Last Post: 19th May 2009, 18:47
