I have several Xvid files with MP3 audio (VBR). Each file is in perfect A/V synch, but when I join them the audio gets ahead of the video. As a result the joined file has no audio in the last part of it. I use the AVI joiner from Boilsoft for the joining.
Is there another tool or method I could use to keep the audio and video in synch?
Thanks in advance.
File/open load you first file
File/append load your second file
Save, make sure you add .avi to the filename.
Libmad - http://www.underbit.com/products/mad/ as far as I know I don't have that program installed and avidemux works fine.He's a liar and a murderer, and I say that with all due respect. -
Thanks, it worked great but isnt there a way to load all the videofiles in one step? Its rather demanding when joining 10 x 10 clips.
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 18:57 -
Joining MP3 without 'blips' and synch loss at the joins?
By bizzybody in forum AudioReplies: 5Last Post: 8th Feb 2010, 02:45 -
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 02:49 -
Joining abr vbr cbr audio videos (maybe cut/paste too)
By ZZen in forum EditingReplies: 2Last Post: 29th Jun 2009, 09:26 -
Audio synch issues when converting to XviD or DivX
By baduncan in forum Video ConversionReplies: 3Last Post: 15th Dec 2007, 14:25
