Hi I have created an mpeg using Mainconcept MPEG Encoder and then authored using TMPGENC DVD Author as I have done several times before with no problems. However a particular player (Onkyo DR-L50) seems to play the audio from the background menu clip but not from the other chapter clips... all of which are mpeg2's created using Mainconcept.
Any ideas?!![]()
Results 1 to 11 of 11
yeah thats what i thought, however all of the original avi's were created in the same editing program using the same timeline properties, then converted to mpeg using the same settings, and authored/burned as one... I cant see any reason why this audio file mismatch would have occured. Maybe i'll make another disc and just check theyre all exactly the same...
Which tool can I use to check the audio properties of the mpeg files? Kind of like GSpot but a program that also works with mpegs?
This would save me re creating the entire DVD.
Thanks -
My guess is if you check the VOBs you'll find that the menu audio has been reencoded to PCM by TDA, while everything else retained the original audio format which appears to be incompatible with the player. To check, play them using PowerDVD. While playing, right click on the screen and select Show Information.
Buy My Books -
What guns1inger said.
I would use AC3 for your audio. Both AC3 and MP3 are supposed to be fully supported in PAL land, but it might be a quirk with this particular player since that is not the case in NTSC (although I've never had a player that didn't play MP3). BTW what version of TDA are you using?"Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Hi,
It is version 1.5.20.62
It was indeed the case that the BG video was PCM audio and the rest mpeg 2. I have now changed this in TDA and I'm authoring now.. I'm pretty sure this will solve the problem.
For future reference is it best to change all of the audio formats to PCM anyway? Are they more compatible with a wider number of players?
Thanks to all for your help -
PCM is the most compatible, but as guns1inger pointed out, it takes up a lot of disk space, leaving less for the video. And if your source audio was a compressed format, there is no advantage to decompressing it to PCM. As i said, your best bet would be to use AC3 for your audio. Most compatible with good compression and good sound.
Edit: Note that with the version of TDA that you are using, you can author in AC3 but TDA can not play it while setting chapter points and such unless you have the AC3 plug in."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
is the AC3 plug in free? I have a feeling I have it already, what utility can I use to check what plug ins I have installed?
The AC3 plug in is/was not free because Pegasys had to pay royalties. (I don't know if you can still get it.) I'm not sure how to check if you have it or not since I never bought it.
Edit: I guess just select a a source file that you know has AC3 audio and try to play it in the "set chapters" time line. If you hear audio you have the plug in, if not, you don't."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books
DVD-Lab Pro 2: How to set a looped video as background of a menu?
By Stern77 in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2010, 12:00 -
Question how to change background menu picture on DVD
By jimdagys in forum Authoring (DVD)Replies: 15Last Post: 8th Dec 2008, 00:55 -
DVD Menu Image Buttons With Video Background
By sk8_aholic in forum Authoring (DVD)Replies: 3Last Post: 20th Nov 2008, 00:01 -
Can background from DVD Menu be extracted from buttons/subpic?
By Scav2003 in forum Authoring (DVD)Replies: 4Last Post: 23rd Oct 2007, 18:54 -
DVD Lab, Is it possible to add video to background on the menu
By frozenwind in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2007, 11:09
