Hi, Im Greg. My brother had a camcorder and he lost it. He has some video on tape that He recorded with the camcorder. I dont know what type of camera it was or how old it was. We would like to convert those tapes to DVD somehow.
They are 8mm Video cassettes. TDK HS30. I assume I would have to record them to HD and then convert, but how could I do this?
Could they be played back on another camcorder and recorded with computer? or what other options would I have if any?
I have alienware area 51 notebook with win xp home. I use DVD lab studio, Video redo, TMPGnc, and AVS Video tools.
Greg
The simplest way, if you can get one, would be a Digital-8 camera that can output DV. Connect this via firewire to your laptop to transfer, then edit (in DV avi format), encode to mpeg-2 and author.
Next option would be to daisy-chain a standard 8mm camera to a DV camera that supports analogue pass-through, and then to the laptop via Firewire, then finsih off as above.
Otherwise you will need an external device of some sort. This could be a USB mpeg-2 encoding capture device, or a standalone analogue to DV converter.Read my blog here.
video cam can suite 8mm tape/cassette
By happytony in forum Video ConversionReplies: 1Last Post: 24th Aug 2011, 00:33 -
By happytony in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 23rd Aug 2011, 23:55 -
Help me with a project. Convert 8mm film to DVD.
By flyin-lowe in forum Authoring (DVD)Replies: 5Last Post: 8th Oct 2010, 09:37 -
Newbie : How to convert PAL into NTSC Format for Video Cassette Player
By kato2010 in forum Newbie / General discussionsReplies: 7Last Post: 11th Sep 2010, 11:40 -
Capturing cassette audio - convert to wavs - will this work?
By Theresa in forum AudioReplies: 12Last Post: 16th Aug 2009, 04:33
