Hello, I am new and don't know anything.
I would like to know how do I play movies that I have on my laptop to my TV.
What are the things I need, and how to do it?
Thanks,![]()
Alex
Results 1 to 10 of 10
First you need to find out what outputs the laptop has.
For instance, my Toshiba has a VGA output, and an S-video output. I just hook up the s-video out and a 3.5mm stereo jack to stereo RCA cable from the headphones to my home theatre amp, and I get a pretty good picture.
If you only have VGA out (rare on anything three years old or newer) then you will have to get a VGA to composite converter. At which point you might consider whether or not it is worth it and just buy a portable player instead.Read my blog here.
What video outputs does your laptop have? I'm guessing S-video and VGA. If you have a TV that accepts either, then it's easy. Some S-video outputs also may be able to use a adapter for composite video, though that will usually not look too good on most TVs. S-video should look OK. VGA would need a add-on converter if your TV doesn't have that input.
So you would need to check your laptop manual for TV type outputs and your TV manual for computer type inputs.
And welcome to our forums.
EDIT: guns1inger beat me by 6 seconds.
Hello All,
I have the svideo output and my tv has as well. I plug on my laptop and tv, but nothing shows....I have a movie downloaded in my laptop but it doesnt show on my tv....do i need anything else?
thanks -
Once you have them connected, you then have to tell you laptop to direct the output to the TV. On a Toshiba it is Fn+F5. I find with mine, and the crappy Intel graphics it has, that I have to direct it's full attention to the TV or else I get jerky output. If you have better graphics you may be able to feed both the TV and the laptop screen at the same time.
Once you switch the output across to the TV, you see the entire computer screen on your TV. It may not be clear, but it will be there. Load you avi into the player and see what happens. If you see a black display area in your player instead of the video, go into the advanced setting of the Graphics Properties -> Display Settings and turn down hardware acceleration until it shows up.Read my blog here.
ok, how do i do that? I have a dell laptop inspiron e1705
thanks -
I got it, thanks...
Now how do i make the sound come out on the TV, because the sound now is only through my laptop....
thanks -
How does one play from a DVR to a laptop screen
By lookingforhelp in forum DVB / IPTVReplies: 4Last Post: 18th Jun 2011, 10:55 -
Laptop unable to play DVD-9
By LadyMiir in forum Software PlayingReplies: 8Last Post: 6th Jun 2011, 07:52 -
How do I play/convert .MP4 files to play on my laptop
By tfoster in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2008, 21:23 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 11:38 -
How to watch downloaded HD movies with no HDMI slot on laptop
By whiteshadow in forum Newbie / General discussionsReplies: 3Last Post: 10th Dec 2007, 06:04
