Looking for DVD burning software that is vista compatible. I am running Vista Home Premium. I want to be able to make copies of DVD’s. Mostly copies of home movies for family. And eventually I would like to create backup copies of purchased DVD movies. I have one DVD drive/burner in my PC. I will buy a 2nd DVD player if necessary. Thank you for your advice.
Imgburn will burn DVDs. DVD Fab Decrypter to decrypt commercial DVDs.
CogoSWSDSOld ICBM Coordinates: 39 45' 0.0224" N 89 43' 1.7548" W. New coordinates: 39 47' 48.0" N 89 38' 35.7548" W. -
DVDFab HD Decrypter to rip the original to your HDD
DVD Shrink to re-author or reduce the size to fit a single layer disc.
Imgburn to burn the results.
Note : for your home movies you can just use Imgburn. Create an ISO disc image on your HDD, then burn to a new disc. The other two are for working with commercial discs.Read my blog here.
What Is The Easiest Video Editing Software For Beginners That's Free?
By Joshua P in forum Newbie / General discussionsReplies: 19Last Post: 16th Apr 2013, 08:24 -
Basic DVD Burning for Mac
By The Monkees in forum MacReplies: 8Last Post: 9th Mar 2010, 17:30 -
Mac special effects software for beginners
By aybayray in forum MacReplies: 2Last Post: 8th Jul 2009, 08:24 -
Is the Hp DVD740 a good choice for basic DVD burning
By EthansMom1030 in forum DVD & Blu-ray WritersReplies: 4Last Post: 11th Feb 2009, 09:03 -
Basic DVD Burning Question
By harryk in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2007, 04:55
