I cut / ripped my first DVD last night ....It came out great XCEPT
The characters stutter when they move (dropped frames) ???
Is this due to DVD2AVI or DVDDecryptor ? I don't think it was TPMG ...Anyone else have this problem ?? I was following SEFY's guide and all went well except that ..... So it is NEAR perfect but close doesn't count with the stutter.
You need to give more info. Where is it "stuttering"? Is it in a burned vcd, svcd? vbr,cbr? settings? etc does it Stutter in WMP or just in your stand alone dvdplayer? maybe your bitrate is set too highg for your dvd player.
Sorry...Here is more data. I had posted earlier with more info
I used DVD Decryptor to copy
Then DVD2AVI
Then TPMG to create a MPEG 1 VCD NTSF compliant VCD
In both PC and DVD player, picture is BEAUTIFUL and minimal motion is fine. But if SNOW white swings here arms, prince charming rides a horse, its like being on drugs. You see ghosted images of movement "like a stutter' . If they stop, the picture does not have a FLICKER to it at all.
It is different than dropped frames where dropped frames look like a miniscule pause, this is more like a jitter.
Any thoughts ???? -
1) snow white is of type FILM, PROGRESSIVE, 23.976 FPS (as stated by the info box in dvd2avi when you start creating the project file...or just press f5 when you load the vobs into dvd2avi)
2) this means use FORCED FILM in dvd2avi
3) in tmpgenc, u need to use the NTSC >>> FILM <<<< template rather than just the regular NTSC template
4) other possiple causes of the juttering could be you choose the wrong field order (the juttering will only show up on TV, not computer monitor)....this assumes you turned FORCED FILM off in dvd2avi and made your output video interlaced, rather than use 3:2 pulldown in tmpgenc
5) also, make sure you set motion search accuracy to high quality (slow) -
That was EXACTLY the problem...Thank you so much..Now I have also learned something new also !!!
Actually I always leave forced film on in dvd2avi, so far even when I have come accross the very rare interlaced dvd the final product has come out fine.
sommersby,
are u sure the one's you're talking about is only a small percentage interlaced. the movies that are 100% NTSC or close to it will not come out right if you use forced film in dvd2avi because they're not film, they're NTSC.
Video Stream Recording Question (Looking for answers)
By likwid8 in forum Video Streaming DownloadingReplies: 2Last Post: 2nd Oct 2009, 10:58 -
Answers to Windows Movie Maker
By GimpGuy2000 in forum Newbie / General discussionsReplies: 13Last Post: 8th May 2008, 18:00 -
Common questions and answers.
By Faustus in forum DVD RippingReplies: 31Last Post: 27th Feb 2008, 06:21 -
Troubleshooting VGA to TV Problems - Looking for Answers
By nathanhj in forum Newbie / General discussionsReplies: 5Last Post: 17th Feb 2008, 21:00
