Hi,
I was wondering if anyone could recommend a dvd player I can purchase that has a region-free hack, and is relatively cheap, but reliable?
I purchased the Phillips DVP5140 in Dec - on $50, but iit's already broke.
thanks!
http://www.world-import.com/dvd.htm or http://www.220-electronics.com/dvdindex.htm are a couple of places to look.
Thanks, but I'd like to do the region-free hack myself, and not pay the mark-up they charge
A dvd-player that I can purchase locally would be ideal - again, not looking for super-duper, just good and reliable with a good price tag. -
There's never any guarantee a region free hack is available - even if it's the same make and model as you find a hack for. The manufacturer may have changed the firmware or chipset or anything while keeping the "label". If you want to be sure to get a region free player, buy a region free player.
I've found the cheaper the player, the more region free players you'll find. Expensive brand players are rarely region free.
/Mats -
And to add, sure, they charge a 'mark up'. But they also usually provide a warranty. If you hack the unit yourself and it quits or you mess up the hack, your manufacturer won't honor the factory warranty because you modified the unit.
Unless they've been "chipped" -- preferably by an outfit that's been doing this for many years. I'm aware of this oneOriginally Posted by mats.hogberg
http://dvdcity.com/
which has long had many models from Pioneer, JVC, Toshiba and other major brands, but I'm sure there are many other such dealers. Several of the ones they carry are rather pricey. And as has been noted, whatever warranty there is will then be from the dealer, as the mfr. is going to disown you.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
Oppo DVD players are highly regarded and can easily be made region free by pressing a few buttons on their remote controls. They are universal players (support Divx, SACD, DVD-Audio, etc.) with very good PAL to NTSC conversion and SD DVD upscaling capabilities.
buy the DVP3960/37 from walmart.so you can easy return it
good quality isn't cheap.
http://www.oppodigital.com/dv980h/default.asp
Recommendation for Blu-Ray player that can have region free DVD
By noob1391 in forum DVD & Blu-ray PlayersReplies: 18Last Post: 28th Oct 2012, 07:17 -
region free dvd player
By madelyne in forum DVD & Blu-ray PlayersReplies: 7Last Post: 31st Jul 2010, 10:55 -
region free dvd player help
By captgeobob in forum Newbie / General discussionsReplies: 22Last Post: 19th Dec 2009, 20:31 -
Recommendation for Multi Region DVD Player/Recorder
By musicandhockey in forum DVD & Blu-ray PlayersReplies: 1Last Post: 20th Aug 2007, 14:41 -
How to Make a Pioneer DVR-520H Region 1 a Region Free player?
By Ossocao in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th May 2007, 22:35
