Hi there,
I used a video camera with a hard disk which records footage into MPEG-2 format. I'm using Pinnacle Studio 9 Software to edit but it will not edit files in the above format. (It allows me to add footage to the timeline but it will not play in the preview window.)
I have tried using an MPEG to AVI converter which results in loss of audio and although I can rip the audio and sync them together it is a very boring and time consuming process.
Does anyone know of perhaps a codec or a really reliable converter which would help me overcome my problem?
Thanks in anticipation
Neale
Welcome RuckusVideo
Check on updates for it ... it should be updated to version 9.4 . -
I would consider switch to another editor that handles mpeg2 much better like Mpeg VIdeo Wizard.
I've used v 9.35, and it does handle mpeg2.
BUT, if your clip has AC3 audio, you must pay Pinnacle to activate the plugin for Dolby / AC3. Otherwise the clip won't play.
If the audio is wav/PCM, then I'm not sure what your problem is.
Although Studio 9 always worked ok for me, I only worked with DV-avi. Everyone kept advising me that editing in mpeg would lead to quality loss.grannyGeek ~~
Antique Newbie -
Check the Hauppauge site. I believe theres a free mpeg editor you can download. It should handle mpegs2 like a champ considering their cards encode to that.
Try mpeg streamclip on the clip . -
If you're not married to a Pinnacle only solution, both MPEGVCR and VideoReDo can edit MPEG-2 video with AC-3 audio or MPEG I layer II audio (NOT MP3 audio, but you shouldn't have that anyway). Both allow you to "try before you buy". By the way, MPEG Video Wizard is by the same people are MPEGVCR, it's just a more advanced product with more options.
Extracting/editing security footage
By lisabee35 in forum Video ConversionReplies: 9Last Post: 15th Jul 2013, 11:03 -
Best settings and format for ARCHIVE footage ?
By Bansaw in forum Video ConversionReplies: 11Last Post: 28th Apr 2012, 09:55 -
Green bars when editing 720p footage
By lathh in forum EditingReplies: 1Last Post: 1st Feb 2011, 13:58 -
Editing on a 16:9 project but have 4:3 footage...
By Undead Sega in forum EditingReplies: 2Last Post: 19th Dec 2008, 13:47 -
Editing Concert Footage
By cereboso in forum EditingReplies: 6Last Post: 3rd Aug 2008, 18:27
