I got AVI with MP3 audio. Voice level of the MP3 is little low. How can i encode the voice or general sound level to be louder?
When i put that AVI to AVI_GAIN folder and double click AVI_GAIN_Regular.BAT, nothing happens..?
Got it done. I just had to change cmd startup path to default. Anyway, that program did good job - audio is now much better. Thanks!
Noticed that it changed file format from xvid to divx. Why? -
Hi Digiface:
It's the remuxing process that's responsible for that. It comes from the DivX toolkit. I wouldn't mind swapping it out, but it's a really good muxing app. If you absolutely need to keep the fourCC info as Xvid, let me know and I'll post a modification for you to try out. Problem is, when you fix one problem, you create 2 new ones...
Here's a simple app which will change the FourCC for a directory of files.
fourccchanger.zip
FFDshow audio decoder level is way too low...
By MidnightMike in forum AudioReplies: 2Last Post: 4th Dec 2010, 00:34 -
Need help with low level hum (audio attached)
By sdsumike619 in forum AudioReplies: 10Last Post: 22nd Aug 2010, 02:34 -
low voice in AVI
By Vossy in forum AudioReplies: 1Last Post: 22nd Jan 2010, 03:13 -
Re: low cost mic fro voice dubbing?
By tomcat862 in forum AudioReplies: 8Last Post: 8th Apr 2008, 02:41 -
How do I record a my voice at a good sound level?
By OM2 in forum Newbie / General discussionsReplies: 6Last Post: 15th May 2007, 13:31
