Hi everyone:
Do we still have Sefy's simple but wonderfulguide on how to make MPEG (DVD, SVCD or VCD) files from a DVD? I mean the guide which uses Smart Ripper, DVD2AVI and TMPGEnc.
I remember the basic steps in the guide and followed them, using the DVD (NTSC).mcf template to make an MPEG2 file from my homemade DVD. I must have used the wrong settings for the template because some of the scene transitions in the MPEG2 file became quite noticeably jittery, even though they are very smooth in the original DVD.
I tried to find the guide to see if I missed something but could not find it.
Here's what I did:
1) I used Smart Ripper to rip the entire DVD.
2) I used DVD2AVI to create a .d2v file and its corresponding wave file in the same folder.
3) I used TMPGEnc, loaded the .d2v and the wave file, chose the folder to save the MPEG2 file. For settings, I chose: constance quality, interlace, 9-bit DC component precision, and "highest quality" for motion search precision. These are the only 4 video settings that I could change.
The result was not good. Although the picture is very sharp and clear, the color very good, some scene transitions are jittery.
I am sure I missed something because I used Sefy's guide a few years ago to make a SVCD. The quality of the MPEG2 file was excellent.
Please help.
p.s.: I am still using Windows98 and PIII (600MHz).
				Results 1 to 9 of 9
	What is your intended "end result" to be? Are you trying to make a SVCD or what?
 I mean a DVD Video already uses MPEG-2 video so there are many different ways to extract a MPEG-2 video stream with an audio stream from your DVD Video and make a MPEG-2 file with muxed audio ... all without doing any conversion.
 Unless you want another format like SVCD etc.
	Hi FulciLives,
 I intend to make an MPEG2 as of now. I used the DVD (NTSC).mcf template because I think it's better then the SVCD (NTSC).mcf template.
 I don't intend to author it, either as DVD or SVCD, at the present time. My DVD player can play MPEG2 file.
 I use Sefy's guide because TMPGEnc allows me to edit (cut & merge, for example) the file with other MPEG2 files that I already have, with precision.
	Well basically you are re-encoding only so you can edit.
 Instead you should use a MPEG-2 EDITOR that does no re-encoding.
 Examples: VideoReDo and MPEG-VCR
 Of course you will have "issues" with your operating system since you have the 4GB barrier to deal with ... a barrier that doesn't exist with other, newer versions of Windows (that use the NTFS file system as opposed to FAT32 as used by Win98).
 My point is you can do what you want without re-encoding which is what you should strive for as any re-encoding will introduce quality loss.
	Yes. You can edit and merge with VideoReDo and/or MPEG-VCROriginally Posted by moviebuff2
 I think one or the other ... if not both ... have downloadable trail versions so you can try 'em out first.
 - John "FulciLives" Coleman
 P.S.
 Please note the two files, in order to merge, will have to have the same type of audio and file attributes. For instance you can't merge 25fps with 29.970fps or one with AC-3 with one that has MP2 audio etc."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
	Hi FulciLives,
 I used VideoRedo. Here is the result:
 1) VideoRedo precisely cut the vob files and produced excellent MPEG files with AC-3 audio.
 2) To join different MPEG files that total more than 15 minutes, I had to register to get the free trial code. I did.
 VideoReo did a fine joining job in video but not in audio. There was a slight " audio interruption" at the connection point.
 Thanks for your help.
	I am glad it worked out for you
  setting the correct colormatrix in x264By codemaster in forum Video ConversionReplies: 1Last Post: 2nd Mar 2012, 23:14
  when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57
  NTSC 23,97 3:2 flag - is this correct?By perik in forum Authoring (DVD)Replies: 8Last Post: 3rd Jun 2010, 13:46
  tmpg dvd author - pal ntsc setting?By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 15:39
  deciding on the correct resolution setting when converting to mpeg2By Dreadnaught in forum Video ConversionReplies: 4Last Post: 15th Jan 2008, 09:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
