I am a newbie to this forum. Hoping to expand my knowledge on this site.
I have a question about charging the batteries on my Canon GL2 camcorder on an upcoming fishing trip to Canada. It will be a fly-in trip and the only power source is solar powered batteries for the lights in the cabin. My question is, can I buy an inverter and put battery cable clamps on it, and attach it to the batteries to power my A/C charger so I can recharge my batteries at camp?
Thanks ahead of time for your help
buy a couple long life batteries for the cam and bring them with you. don't use the lcd screen to conserve power while recording.
Charge up and take a couple of these Click Here
If you have an auto adapter for your cam you can plug it in directly otherwise get an inverter and use your ac adapter.
Edit: As far as using an inverter on the Solar Cell batteries at the cabin, that will work as long as the inverter is rated for the voltage of the batteries. The only Solar Cell set up I've seen the batteries were 24volt and won't work with the standard inverter you would normally find, which are designed for 12volt Automotive batteries. But that doesn't necessarily mean that the ones at that cabin are 24volt, it just means you'll have to find out yourself. Of course if you screw up and short out the lighting system, the owner isn't going to be very happy with you and may leave you there permanently."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
I've used one of those 'jump starter' units with my laptop, along with an inverter and it works fairly well. They use gel cells, so there should be no chance of leaks.
Alternately, you could use a solar charger and a camcorder battery charger that runs off 12V.
http://www.batterystuff.com/solar-chargers/SP60-12.html
http://www.calcellular.com/can-bp-915-charger.html
Video Files of our trip
By wongwinwongwin in forum Software PlayingReplies: 3Last Post: 22nd Apr 2011, 07:57 -
Charging indicator won't stop blinking
By tee jay in forum Portable VideoReplies: 2Last Post: 17th Jul 2010, 00:06 -
Hulu to start charging for subscription based service in 2010
By freebird73717 in forum Newbie / General discussionsReplies: 11Last Post: 24th Oct 2009, 14:15 -
Thailand trip
By TripMaker in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2008, 22:58 -
Copying a DVD for trip
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2007, 14:41
