Hi All,
Can someone tell me if the standard stereo audio cables terminated with RCA jacks used for left and right stereo channels can be used for connecting digital audio out between say DVD player and A/V receiver (using one just one of the physical connections (red or white) ? Essentially are these standard audio cables interchangeable for analog and digital audio home theatre applications? Are the impedances the same?
I thought I had read somewhere that the digital coaxial cables are 75 Ohm cables and the standard red/white audio coax cables are a different impedance??
Any input would be greatly appreciated.
Thanks,
radiowhiz
It's not only the impedance factor, but analog audio and digital audio operate at different frequencies, so the cable may not be designed to carry the frequency range of digital audio. If you have a RCA composite video cable, that would work much better since digital audio operates at about the same frequencies as analog video (and the impedance is the same @ 75 ohms). In fact, I use a digital audio cable as a composite video cable in my system.
Hi there,
Thank you for the response.
Good point re: freq. response too. Your response triggered another question ... For component inputs (Y, U, V), what are the cable requirements? I've noticed that cable vendors will market specific component cable sets but I suspect there is a tendency by AV end users to reuse existing composite/audio cables if they have them kicking around because they supply 3 bundled coaxial cables with RCA terminations as well. But as I vaguely recall, component cables are carrying color differences and may be carrying mixed signals (AC on a DC bias) so what is acceptable for these connections?
Thanks in advance,
radiowhiz -
Coax S/PDIF audio and analog component (YPbPr) all use the same 75 ohm coax as analog composite (yellow). Analog component YPbPr comes in standard definition (under 8MHz analog bandwidth) and high definition 720p/1080i/1080p (15-60MHz analog bandwidth). High definition application needs better quality (e.g. double shielding) and will video quality degrades faster as cable length increases.
If it's a digital signal you're trying to pass, you can try any kind of cable. The result will be either acceptable or a failure. There's no 'distortion' involved. Analog signals, OTOH, can have varying degrees of success and cabling parameters can cause distortions.
Question regarding Home theater projector
By jtrinc in forum Newbie / General discussionsReplies: 5Last Post: 11th Dec 2009, 14:41 -
Question about home theater system (Audio)
By jtrinc in forum AudioReplies: 37Last Post: 9th Jul 2009, 19:51 -
Home Theater in a box audio- No Dolby Digital?
By PhoneMatt in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2008, 15:34 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 12:47 -
What will happen to analog cable after the digital switch???
By yoda313 in forum Off topicReplies: 5Last Post: 12th Jun 2007, 18:32
