hi
i have a kworld capture card.
i installed the drivers of the card and the inter video winDVR to record video.
when I run inter video winDVR to record , a green screen appears and i can't see anything to record.
i'm having this problem in winxp sp2.
in winXP sp1 i didn't have this problem.
actually when i play recorded files by power DVD i can't see anything and again that green screen appears...
what should I do to disappear that green screen and see videos?
Everything I have seen in the recent past always points to an issue with your graphics display overlay settings ... But dont go any further into detail .
Strange , there are quite a few posts going back over time that never received any attention to this problem .
The only times I have seen this appear are :
A : Incorrect version of video drivers installed , not entirely compatable with installed video hardware .
B : An issue bound to codec / directshow fault .
The second is not for someone to just jump into ... wrong move , and you might be facing a complete reload of the operating system again .
Some tools that might help , when one knows how to use them correctly :
Filmerit , codec sniper , radLight filter manager , directshow filter manager .
I have snapshots from filmerit which show all the xp + sp2 system default values from a clean reinstall of the os just for troubleshooting such issues ... just got to add codecs not os connected to the list later .
The other triggers to watch for are :
A: Poor install technique .
B: Bad installation of device .
(A) starts off with :
1: Install software and in some cases , the software that came with device will install the device drivers .
2: Shut down pc , install device , reboot , os picks it up from there (may request drivers again)
3: When system says all ok , reboot prior to activating device .
(B) is :
An example of a midi motherboard
==== (agp slot + onboard vid)
--- (pci1 = do NOT install any device here) ... shares resources with agp slot and onboard video .
--- (pci2 , shares resources with pci3)
--- (pci3 , shares resources with pci2)
This leaves a choice between pci2 or pci3 to install a pci capture device ... Only (1) may have a device installed .
There are RARE instances where this may be ignored , but it is highly recommend you dont , as conflict / damage to , may be the end result to device , and or , pc .
If A and B are correct , then the issue returns to the above .
The final one would be to check for updated drivers for the card from the manufacturer that fully support sp2 .
Kworld device could be anything ?
Take notice of id lables , and what is stamped on the major chipsets for proper identification ... most devices these days use FIC ID lable on the underside .
TMPGEnc green screen
By BobAchgill in forum Newbie / General discussionsReplies: 3Last Post: 18th Jun 2010, 16:06 -
How to use green screen with video?
By MitchStevens in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jun 2009, 19:33 -
By MitchStevens in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Jun 2009, 09:44 -
Screen turns green
By boysha in forum Newbie / General discussionsReplies: 2Last Post: 31st Dec 2007, 13:46 -
green screen in convertxtodvd
By fruitpassion in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jun 2007, 00:16
