I was able to utilize ripit4me together with its three companion programs to rip an older DVD called Forbidden Planet. This DVD happens to be a widescreen edition on one side and a standard screen edition (4:3) on the other. I processed the widescreen side. Somewhere in the process, it mentioned that CSS was used as copy protection.
Everything ran smoothly. I ended up with ten files; six of which were vob files plus two .bup and two .ifo files. At this point, I was not sure how to go about burning a DVD with them, so I imported them into WinDVD Creator. I burned a DVD which played OK on my living room player.
Problems: First there were several short clips which had no sound associated with them. I thought the whole thing was NG, but eventually, the main movie started, and the sound was fine -- even in sync. The picture, however, seemed to have rather poor resolution, certainly not as good as the original. Also, the aspect ration was such that the human subjects all seemed stretched, mostly in the horizontal direction. The color seemed OK.
Can anyone suggest the best way to have burned the DVD? How does one produce better resolution? What about the aspect ration?
Thanks for any comments.
pauldb wrote"Can anyone suggest the best way to have burned the DVD?
IMGBurn........
http://forum.imgburn.com/index.php?showtopic=1780" Who needs Google, my wife knows everything" -
Originally Posted by pauldb
http://www.digital-digest.com/~blutach/pgcedit_guide/burning_with_pgcedit/burning_with...pgcedit_v2.htm
If you need to shrink a dual layer DVD to single layer size for burning, DVD Shrink is the best tool for newbies to use.
Your problem almost certainly is that WinDVD Creator changed the aspect ratio of your rip to 4:3 when it created the DVD you burned. What you are seeing is consistent with a 4:3 video being stretched to 16:9 size. Had WinDVD Creator put a 16:9 flag in the video, you would not have this problem. Yes, I DO understand that you ripped a widescreen movie, but WinDVD Creator encoded the flag as 4:3, so when you tried to watch it in 16:9 mode on your TV, you were seeing a 4:3 encoded movie being incorrectly stretched to fill the screen, even though the film actually was in 16:9. The aspect ratio got messed up by WinDVD Creator, although if you knew what you were doing, it was possible to fix this with IFOEdit prior to burning the DVD.
Clicks heard on my OST's CD; actually there or a poor ripping job?
By takearushfan in forum Newbie / General discussionsReplies: 10Last Post: 4th Feb 2012, 00:56 -
Poor VHS or Poor VCR?
By ryangarfield in forum RestorationReplies: 10Last Post: 7th Jun 2010, 06:34 -
Ripping and modifying commercial DVDs and menus
By rassilon256 in forum Newbie / General discussionsReplies: 2Last Post: 9th Feb 2010, 06:30 -
Ripping subs from a poor recording?
By bmwracer in forum SubtitleReplies: 0Last Post: 5th Dec 2007, 14:37 -
DVD Ripping-poor result
By pauldb in forum DVD RippingReplies: 8Last Post: 6th Aug 2007, 19:31
