I have been backing up movies for a long time now without a single problem. I recently backed up Venture Bros. Season 2 and it kept freezing on me. After thinking it was merely the DVD player, I tried watching Zodiac on a different DVD player with the same result. I looked at the back of the discs and noticed a strange line running around the disc. The DVDs are not damaged or anything like that. Has anyone else had this problem?...or have any idea if the problem is with my hardware or the software. I am using Ripit4me and DVDshrink. Thanks guys.
Results 1 to 11 of 11
Not all recordable DVDs are created equal....some are just crap. There is a good chance that is your problem.
www.nomorecoasters.com and our own DVD Media database are good places to start.
Read my blog here.
Use VERBATIM or TAIYO YUDEN dvd media for your movie backups.
So you guys think it may just be the media I am using? I have used Memorex DVDR before without a problem. Maybe I just got a bad batch? The lines I described showing up only show up when I have to compress a file on a disc. Any thoughts?
Memorex don't make DVDR's. They re-badge other brands, usually poorer quality ones.
Exactly as KBeee said....memorsux are hit or miss....you never know what you are going to get...I avoid them like the plague but then again I always have....even their cassette tapes were NOTHING compared to Maxell.Originally Posted by bigmatt72401
Well I d/l Nero CD-DVD Speed Tester and ran it a few times. The first time I ran it, I ran the Scan Disk on a blank DVD it said that all sectors were fine. Then I ran it again on a burned DVD an its not even half way through and its coming up with quite a few bad sectors.
Oh yeah, also, the DVD's are "RICOHJPNR03" if that helps at all...
Burn slower and see if that helps. Depending on the writer/DVD combo, writing slower often helps!
DVD hired movies freezing on PC, a CSS warning (Mostly on 27 dresses video)
By Eleyan in forum Software PlayingReplies: 2Last Post: 31st Jul 2010, 16:11 -
DVD freezing?
By XyBeRz in forum Authoring (DVD)Replies: 10Last Post: 29th Dec 2008, 00:26 -
Tmpgenc keeps freezing
By WinSpecToR in forum Video ConversionReplies: 6Last Post: 12th May 2008, 01:08 -
Computer Keeps Freezing
By Squid_uk in forum Newbie / General discussionsReplies: 14Last Post: 11th May 2008, 08:43 -
1h40min movies became 50min movies after conversion
By oediv in forum ffmpegX general discussionReplies: 1Last Post: 31st Jul 2007, 15:13
