hello all, im trying to add adobe flash videos to my website, im using flash video studio 1.5 to convert the avi/mpg videos to flv
the videos show up on my site and play, but they skip and buffer very much, it plays about 5 seconds then stops for 10 seconds and plays another 5 seconds and keeps doing that
is there anyone here that uses flash video studio and can maybe help me on the converting quality, i have tried to set the quality to poor for both video and audio , and the flv file doesnt play the video right, so now i have set the video to average and audio to best
you can view the videos at
http://www.storethe.info/adam/
which i am currently adding music and videos
please post if the videos skip/buffer alot, if so i may need to convert the flv files to a lower quality is what i am thinking
thanks
----> adamf9898 ---->
I dont use adobe flash video studio 1.5
And from those clips , I wouldnt have wasted the time in uploading them , there rather poor in quality (pixelated) .
Buffering depends on the amount of data the needs to transend over networks , some networks are better than others .
Creed-higher.flv came in nicely , after a second attempt , beforehand , it buffered poorly .
You might want to give this program a run at converting to flv's , and it gives you a sellection as to the choice of connection required ... the higher , the more it will buffer .
http://www.dvdvideosoft.com/guides/dvd/free-SWF-FLV-video-converter-convert-video-to-SWF-FLV.htm
Then there's info on xml playlists . -
yes, i dont want the quality perfect for the adobe flash videos, just a sample for the video if they want to download it, the mpg/avi is also avalible
i have started using the settings in flash studio as , video=fair , audio=good----> adamf9898 ---->
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
Trouble downloading streaming video/flash video from site
By imi in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Mar 2012, 11:08 -
Video Files, join video_ts and flash video
By Pumkinhead in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2011, 06:45 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 09:05
