What is the easiest way to join multiple video files (200+) into one? The video files are from the same source. They are MPEG files.
I tried most DVD software, and they are limited to 99 clips.
Please help.
Thanks.
That is the limit of a title set. That is the dvd spec. You can't have more than 99 clips in one package together if you want them independent. Though I believe you should be able to make title 1 with 99 and then title 2 with 99 and so forth as long as you fit onto the dvd you are going to use.
The other way around is to mix them together. For mpeg you could use tmpgenc 2.5 and use mpeg tools and multiplex. Than you merge the videos together into one mpg file for authoring. Or you should be able to do it with virtualdubmod or virtualdubmpeg2. But those output to avi unless you frameserve to an mpeg encoder.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Easiest way to cut and join video files
By zammil in forum Newbie / General discussionsReplies: 8Last Post: 15th Oct 2010, 13:04 -
How to join multiple .ts files into one large file
By hobbes4444 in forum Newbie / General discussionsReplies: 1Last Post: 5th Jan 2009, 12:29 -
Best/Easiest way to make multiple segments of a mp3 file?
By raydeneg in forum AudioReplies: 4Last Post: 7th Oct 2008, 09:47 -
join multiple video files - free software?
By kj1983 in forum EditingReplies: 2Last Post: 21st Aug 2008, 12:54 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 03:28
