hi there, hope you can help, i use cucusoft avi to dvd pro and convertxtodvd to convert my avi files to a dvd format these's programmes work prefectly well except the picture is sometimes very very dark when played on my tv.the files are perfectly clear when played on my pc, is there anyway i can convert to dvd and not loose so much of the quality of the original file.....cheers in advance nicko
Any conversion, especially using simple tools, will result in, at the very least, all the flaws in the original source files being magnified. There is little you can do about it other than to get better quality source material.
I don't use cucusoft, however ConvertXtoDVD does not make the clips darker, so I would suggest to you that the issue is with the settings of your TV.Read my blog here.
Need help with DVD to AVI conversion
By Chain Reaction in forum Video ConversionReplies: 6Last Post: 12th Apr 2012, 15:46 -
Hd-DVD/VC1 conversion to AVI
By mpiper in forum Blu-ray RippingReplies: 10Last Post: 20th Mar 2011, 21:57 -
DVD to AVI Conversion ???
By babaki in forum Video ConversionReplies: 2Last Post: 22nd Aug 2010, 23:15 -
AVI to DVD conversion
By nick soapdish in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2008, 18:11 -
By mattman1968 in forum Video ConversionReplies: 3Last Post: 22nd May 2007, 09:06
