I'm backing up all of our home-video onto DVDs (avi/mpg/wmv format, not DVD/SVCD). Even though it's just for backup, I'd like to preserve as much quality as possible while still allowing it to fit on a single-layer DVD. The raw DV runs 12.6GB/hr. I tried Virtualdub with Xvid, but even when I specify 4.5GB as output file size, the resulting file doesn't get above 2.4GB.
I thought I'd ask here to get an educated opinion on whether one format is better than others for this situation. Should I be looking at WMV or MPEG-2 instead of mpeg4?
Any opinions are appreciated.
IMHO, if you plan on editing it in the future you should keep it in DV-AVI format to ensure best quality. Break the files into 20 minute segments using VDub in Direct Stream Copy for both Video and Audio.
Buy My Books
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 14:09 -
Why most players couln't play .wmv files > 2.5GB properly?
By tigerb in forum Newbie / General discussionsReplies: 8Last Post: 18th Dec 2009, 02:35 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Is it possible to encode divx files to larger than 5gb?
By yoda313 in forum Video ConversionReplies: 18Last Post: 4th Jul 2008, 12:25 -
Converting 13GB high-def camcorder file to DVD (downgrading?)
By JamesNG in forum Video ConversionReplies: 1Last Post: 8th Jan 2008, 12:28
