I think my two year old programmed my Phillips 642/37 DVD player when he was playing with the remote. We cannot turn it on although the red standby light is on. When you push any other button the DVD player simply turns off. What did my toddler do?
	My husband already did try that, but I'll try it again. Is there a list of "secret" codes somewhere?
	Actually, if you're going to try unplugging it to reset it, I recommend leaving it unplugged for at least thirty minutes... more, if you prefer, even overnight.
 The only 'codes' I've seen for the 642 are the ones that let you change/view the region settings and firmware information. I don't think there are any 'factory reset' codes (at least, any that we know about), and the codes also don't seem to work on any of the newer 642s.If cameras add ten pounds, why would people want to eat them?
  Set "Output filename" As Default Global "File/segment title" In MkvMerge?By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52
  WMV files: Changing "Recorded Date", "Media Created" fields in metadataBy axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27
  "stretching" or "cramming" aspect ratio when I convert .avi to MP4By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 11:30
  Review "HYFAI" MP3/MP4 "Nano" clone from ebayBy NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 06:45
  REMOVE Phillips DVP-642 "angle" indicatorBy gumbico in forum DVD & Blu-ray PlayersReplies: 35Last Post: 28th Jun 2007, 13:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
