Hi,
I have a WDC WD25 00KS-00MJB0 SCSI Disk Device and it picks up the hard drive in device manager and add hardware, ... , however, if you go to my computer it does not show up! How is that to be fixed? Thanks!
Results 1 to 9 of 9
The drive probably hasn't been formatted before. Go to Start, right-click on My Computer and select Manage. Then open Disk Management. Here you can set up a partition, assign a drive letter and format it.
Buy My Books -
What type of computer? Is it XP?
Use partition magic too, also should PREP it for you. -
From what gadgetguy mentioned , it needs to be initialized first , before you can setup partitions and format it .
hiiiii thanks sooo much for all your help everyone. I use winxp pro 32 sorry I should have said that before! Guess what I went to the disk management and everything and it is working now! Thanks sooo much for all the help! I very much apprecaite it! All of you are awesome!
hi,
is it better to format the whole thing or split some of it like partitions or does it matter? Thanks soo much! -
I'd just format the whole hard drive. Just my 2 cents!Originally Posted by Ghtpua
thanks sooo much that is what I did, however, was not sure if it mattered
Hard Drive disappears when computer goes to Stand By.
By Xylob the Destroyer in forum ComputerReplies: 11Last Post: 1st Jul 2010, 14:44 -
I have some VHS tapes that I want to transfer to a computer hard drive.
By marada in forum Capturing and VCRReplies: 15Last Post: 30th Nov 2009, 09:35 -
LG - RH397D advanced hard drive from computer
By Triad123 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Jul 2009, 04:41 -
Direct from DVR to computer hard drive?
By jdcrowley in forum DVD & Blu-ray RecordersReplies: 2Last Post: 29th Sep 2008, 22:08 -
Philips DVP5982 - USB hard drive folders not all showing
By PunkHippie in forum DVD & Blu-ray PlayersReplies: 3Last Post: 18th Sep 2007, 13:58
