    Jul 2007
    I have some divx/xvid files with different aspect ratios. I have been using dvd flick to burn my movies to dvd but it always sets the aspect ratio to 16:9 widescreen. this looks fine on most movies but on others you can tell there is a stretch. what is the best burner program i can use that will just keep the original aspect ratios for divx/xvid files to avoid the "stretch" look?
  2. Member louv68's Avatar
    Feb 2004
    Minneapolis, USA
    I've been using The FilmMachine and have been pleased with how it preserves aspect ratios and the quality of the encodes, especially when using CCE as the encoder. There is an option dedicated to setting aspect ratios as you walk thru the process step-by-step. I highly recommend this program.
    -The Mang
