    Sep 2006
    hey i have 100's of dvds but some of them are starting to get messed up from being used all the time. so i wont o back them up but i was going to use a EdgeDupe 1 to 1 Duplicator or some other 1 but i coulnd find if it would backup an original dvd dose anyone have a Duplicator that dose or know where i could by one?
    Apr 2004
    Miskatonic U
    No duplicator available to the general public will allow the copying of original discs. Get yourself a copy of DVDFab HD Decrypter and imgburn, a pile of discs, and start ripping and burning.
    Read my blog here.
    Sep 2006
    lol i use dvd shrink but its a slow proses just wonted somethin better
    Apr 2004
    Miskatonic U
    DVD duplicators will only do direct 1:1 copies. They won't reduce the size to put it on single layer discs. This means you would be up for dual layer discs in most cases. Shrink is probably about as fast as you will get. You want faster, then put any cash you might have spent on a duplicator and upgrade your PC to something with dual or quad cpus. This will speed up your transcoding/encoding a lot.
    Read my blog here.
