Whats the best (and easiest) tool to use to simply join to MPEG video files together (one after the other), i have tried several, and they seem to chop bits out, mpegjoiner being one, so somehow i cant just join two files together to make one large one, ie 2 x 32Mb files to one big one, im pretty much a lamen do the easier to do the better.....................![]()
Do they both have the same characteristics ? i.e same resolution, framerate and audio properties ?
If so, Virtualdubmpeg2 or AVI Demux should be able to do it, however you will have to re-encode the results.
if you want to avoid re-encoding then you might try VideoRedo or Womble.Read my blog here.
MediaJoin is free: http://camtech2000.net/Pages/MediaJoin.html simple and fast.
joining files
By maxone71 in forum Video ConversionReplies: 0Last Post: 3rd Dec 2010, 21:33 -
So what's the best software for joining mpeg-2 files together?
By snafubaby in forum EditingReplies: 1Last Post: 23rd Aug 2009, 04:15 -
GUI for dvdauthor, movie from 2 MPEG files instead of joining them together
By Steve Walsh in forum Authoring (DVD)Replies: 5Last Post: 4th Sep 2008, 10:13 -
Joining mpeg-4 files
By GAR in forum EditingReplies: 8Last Post: 3rd May 2008, 23:42 -
Joining mpeg-4
By sp_key in forum EditingReplies: 2Last Post: 22nd May 2007, 09:12
