yo guys wazup
i'm trying to convert a mpeg2 file back 2 a vcd format
i run xp and now i've download the mpeg2 codec but if i want to open the
mpeg2 file with mediaplayer 8 it gives codec error
btw the codec i've download does it work for xp?? or is it imposible to run mpeg2 files under xp??
cuz i start it up and click on install it doesn't do anything or say anything
i've tried to open the file with Vdub and tmpgenc it won't open it
any1 can help me with this one??
thanks in advance
laterzz
Results 1 to 13 of 13
You could load up the SVCD file in DVD2AVI and frameserve it to TMPG like you would a normal rip.
Hope this helps.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
I'm a big time newbie on this. Can you tell me how to convert the SVCD back to VCD? I have TMPGEnc but what were you saying about DVD2AVI? Do I need both programs? There isnt a tutorial on how to do an SVCD-->VCD conversion.
Hi Did you get any help on this? I've been searching the net for some help on this ie SVCD to VCD. I have DUP-DVD which is great but no instructions for svcd to vcd. Help, please. I have only been involved in this for a bout three days but have made SVCD from DVD with DUP-DVD > I am a complete NEWBIE!! Thanks
hi, why do you guys want change svcd in vcd? svcd is a lot better quality. it is almost dvd-quality.
Look to the left under the DVD RIP section. Refer to Sefy's Classical Newbie Guide.
Downlaod and install both noted programs (DVD2AVI v 1.76 and TMPG Encoder.
For serving your clip, Start DVD 2 avi, and browse to your SVCD mpg file. Then run it just like you would for ripping a DVD.
Follow Sefy's instructions, and you should be OK. Hope this helps.~~~Spidey~~~
Thanks .. I'll give it a go! I want to convert the format because my mate cannot play SVCD .. only VCD on his DVD player for his kids.
The way up & the way down are one of the same -
For those whose DVD players dont take SVCD's try this, it worked on my DVD player.
http://www.geocities.com/newestmoviesencode/dvdvcd -
Hey thanks This sounds like a great idea for this problem .. if it works. I'll give it a go and get back to you.
Guys i have tried all the steps above but my player shows a movie with all green blocks and choppiness in the audio
i guess the movies bit rate was too hight hohum i guess i have to encode the movie to mpeg 1 -
Hi I've also followed the instructions/all the steps and I get the green smudge screen on pc. However, I get a problem with audio on DVD player... the picture is in the back clicking and audibly complaining
. Am I missing something in the audio settings. Also TMPGenc doesn't like the conversion. Nero positively objects. Do I burn as SVCD or VCD? Do I change any settings other than to video cd and MPEG 1 from MPEG 2?
Thanks for all the help! -
I am trying to convert svcd to vcd. sometimes everyting goes fine, but sometimes the audio file that dvd2avi creates has -xxms delay, which then makes the audio littlebit off in TMpgEnc. How can I get this delay to be 0ms?? or can I in Tmpgenc join the audio with +ms "delay".
hi, i have followed the instructions, with a svcd ntsc 480x480. tmpgenc did the job in about 35 min. (780mb). nero says it is not the right setting to burn a vcd-cd and ask to go on without the standard-setting. yes and nero burned a vcd -cd. my dvd-player played the 'vcd-cd', with the same quality video and audio as the original svcd-cd. when i try fast forward or backward the film becomes little green blocks, but when i give the order play again, the film plays well again.the 'vcd-cd' is also playable on my pc with powerdvd.if anyone have (other) good settings or a solution for probs, let know it. greetings
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 11:39 -
Converting from DVD to format to play back using media share/directv dvr
By Nosey249 in forum Video ConversionReplies: 0Last Post: 24th Feb 2010, 09:35 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 09:06 -
Back up and converting
By Gustav Klimt in forum MacReplies: 2Last Post: 25th Jun 2007, 15:17
