Has anyone been able to use Virtual Dub (or other 3rd party capture apps) to capture audio with the Asus v7100 DC? I can capture video with Virtual Dub, but not the sound.
When using the Asus Live software, the sound is captured directly (I have attached a cdrom-type audio cable from the video card to an internal 4-pin connector on the sound card). I have tried every input selection (aux, mic, etc,...) for the recording options, but still no sound using VirtualDub (or other 3rd party apps).
The only 'workaround' I've found is to attach the video/sound-out cable (from the back of the video card), then put the sound-out jack back into the microphone jack on the soundcard. Doing it this way causes a 1/16 second delay that makes the audio sound like it's in a tunnel.
Another complaint (besides the terrible Win2k capture driver) is the fact that when using the Huffyuv codec w/ Asus Live, it won't seemlessly start a new 2 Gig file capture (capture1.avi,capture1_1.avi., etc..) like it does using the Asus codec. This really sucks becuse I'd rather live with a slight gap then have to re-capture and re-join them all.
Thanks for any suggestions!
Results 1 to 1 of 1
I have a problem with mp4 files in virtualdub, slow motion audio.
By barbur in forum Newbie / General discussionsReplies: 5Last Post: 12th Feb 2012, 13:16 -
Audio - Video Sync Problem - VirtualDub
By cyberlion in forum EditingReplies: 13Last Post: 16th Jul 2010, 07:51 -
VirtualDub audio problem
By wcdeich4 in forum EditingReplies: 9Last Post: 10th Dec 2009, 21:57 -
ASUS TV Tuner problem with Video in & audio adaptor
By Zpazt in forum Capturing and VCRReplies: 0Last Post: 16th Jul 2008, 14:30 -
Connection problem with Asus router
By tweedledee in forum ComputerReplies: 23Last Post: 3rd Sep 2007, 22:07
