    Jan 2006
    Australia
    Ive read that the best format to uploed to Youtube is MPEG4 (Divx, Xvid) format at 320x240 resolution
    with MP3 audio, at 30 frames per second.
    However I use Ulead to edit my videos and the closest I can get to this is
    MPEG-4 Files
    24 bits, 320 x 240, 25 fps
    Frame-based
    MPEG-4 SP Video: 720 Kbps
    48000 Hz, 16 Bit, Stereo
    MPEG AAC Audio: 128 Kbps
    Is that good enough for Youtube? Ive noticed some of my clips arent very clear.
    If thats not good enough can someone tell me another video editor that is just as easy to use as Ulead Video Editor? I like to do multiple trims ina clip as I cut out highlights from football games and Ulead allows me to do this.
    Jan 2006
    Australia
    Dont worry I found another option I can use.
