Hi everybody!!!![]()
Well, using the Logoaway filter by Krzysztof Wojdon here...
http://www.voidon.republika.pl/virtualdub/ladocs301/logoaway.html
we can remove the TV logos but what I'm wanting is remove a logo from an specified range
Like 15 minutes, 22 seconds and 10 frames to 15 minutes, 23 seconds and 20 frames (25 frames/second)
In the page (the To Do section) Mr. Wojdon state something related that.
http://www.voidon.republika.pl/virtualdub/ladocs301/logoaway.html#todo
Well, I'm brazilian and Mr. Wojdon seems to be polish and recently the TV stations from my country is putting parental marks like his TV stations. You know and I wanna remove them.
And mainly I don't want to split the movie in several parts, remove the parental logo from the parts with it and join everything again... This would be annoying.![]()
Anyway, VirtualDub, AviSynth and any suggestion will be welcome and if this requires the use of an advanced comercial ($) video editor, so please I would like to know.
Thanx and my best regards...![]()
Hi-
As far as I know, you can't designate the frames it's to be used. However, if you switch to the better DeLogo filter, it allows you to specify the range of frames for its usehttps://forum.videohelp.com/topic280003.html#1376335If the logo starts at frame 400 and is on the screen until frame 10000 we will note this as 400-10000. Now say it comes back from commerical and the logo re-appears at 13500 and stays there until 22356 when there is another commerical break. Note this as well and keep going until you've covered the whole video.
Now go to "video" again, choose "filters" click on Delogo (it's already applied) and where it says "on frames" we will type in the frames we want processed. In our example the logo began on frame 400 to 10000. Enter it as 400-1000, then a comma, and the next set. Our example would look like this: 400-10000,13500-22356, etc etc.
Here's a post (in German) that shows pretty amazing results using the DeLogo filter multiple times in an AviSynth script:
http://forum.gleitz.info/showthread.php?p=172450#post172450 -
Buy My Books -
Man, you definetely saved my life!!! That thing is I was looking for!!! Thank you SO MUCH!!! 8)Originally Posted by manono
Hmmnn... sounds interesting... Let me tell you that I don't know about the Trim function but if the Trim function break the video but it doesn't generate any files (the segments) just only the variables you mentioned.Originally Posted by gadgetguy
Anyway, thanks a lot for reading my topic!!! See ya!!!
Remove Spoilers, Logos etc.
By illogical in forum User guidesReplies: 18Last Post: 17th Feb 2017, 08:25 -
Remove Logos
By Bob740 in forum Newbie / General discussionsReplies: 2Last Post: 9th Dec 2010, 12:19 -
easy way to remove alpha logos (with no opaque parts)
By dumbledore in forum EditingReplies: 1Last Post: 16th Feb 2010, 18:22 -
Logos in Credits
By ehmjay in forum MacReplies: 6Last Post: 13th Sep 2007, 21:27 -
2 Logos on a TV Station
By gll99 in forum Newbie / General discussionsReplies: 10Last Post: 23rd May 2007, 17:18
