Hey I just reinstalled XP cause I had a bunch of viruses and spyware. On the reinstall, not my boot drive, but my other hard drive got completely wiped. I had most of it backed up, so I'm not too concerned, but is there anyway to get it back? The weird part is that when I right click the 250 gb hard drive it says that 104 gb of it is being used, but I can't see any files.
Any advice on this?
Tim
Results 1 to 15 of 15
A reinstall of Windows shouldn't touch anything but the boot drive.
Are you sure it's been wiped? Not just unavailable? But you may be able to recover it with a disk recovery program. But don't write anything to it until you try that, or all may be lost.
If you have similar boot and secondary drives and you want to do a reinstall, it's a good idea to unplug the secondary drive as Windows may not be able to tell one drive from another.
I always repartition and reformat my boot drive for a reinstall of the OS. That gives me a 'clean slate' to work with. Difficult to recover, though, if you had data on it you might need. I always stick to the (my) 'golden rule', Don't put anything on a hard drive that you can't afford to lose.
Anytime you do a major overhaul of the OS, you want backups.
Have you check your recycle bin?
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Yeah I have 3 hard drives right now. SATA boot drive, and 2 IDE large storage drives. The crash was in one of my large storage drives. It wasn't a huge deal, but it was kind of annoying. The funny thing was I was reorganizing stuff so I could back more of it up, and reinstalling XP was part of the process, haha.
Thanks for the advice
Tim -
Yep, Had the same thing happen to me with SATA master drive and IDE slave re-install wiped all files on SLAVE. Told by a Techo when re-installing disconect your SLAVES otherwise you might have a FRESH install on your slave or a reformatted Slave. Looks like SATA Have problems at this stage with working with IDE Drives.
That was what I was going to recommend. I have also seen an instance where if you didn't disconnect the slaves, the boot record was on the wrong drive.Originally Posted by OzzyDownunderBelieving yourself to be secure only takes one cracker to dispel your belief.
This is interesting...
There are several releases of XP. With some you need a previously installed OS on the disk, with some others you need a clean disk to install and there are some others that will allow you do do pretty much whatever you like.
Branded XP disks (IE: DELL) used to delete everything before they install. -
Been there, done that, bought the teeshirtOriginally Posted by dimtim
Since then have always physically disconnected my data drive before reformattting or cloning the system drive.Try TesDisc 6.7. If that doesn't work, nothing will.Originally Posted by dimtim -
I seem to remember reading awhile back that this was a feature/bug of the XP install package.
Google is your Friend -
Just dis-connect your D-E-etc HD's when you install re-install XP on your C drive. Re-connect after you update. I've installed XP many times on multiple HD systems and never had this problem.
O&O DiskRecovery will recover data from a formated HD. Just select the right option and do not write anything to that drive. -
You have to install Service Pack 2 in order to XP to recognize a drive of such magnitude.
Once you install SP2 all will be normal again.1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!! -
The data is still in the disk but XP is not recognizing it.
I hope that you didn't mess with it yet.
Install SP2 and the drive will be "availiable" again.
Let me know how that worked!
What MeDiCo_BrUjO said sounds correct.
Did you install from an original XP disk (with no service packs slipstreamed)? If so, then you need to enable 48-bit addressing. I know that it is native to SP2, but is NOT available in the original version - don't know about SP1.
Once you have messed with a drive with 48-bit addressing with a non 48-bit addressing OS, you may have lost everything above 137GB on your HD. Your best bet would be to create a slipstreamed XP with SP2 and reinstall XP.ICBM target coordinates:
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 19:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Windows not recognizing all hard drive space after reinstall.
By GLE3 in forum ComputerReplies: 2Last Post: 12th Mar 2009, 10:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 12:06
