AudioVCD batch problem
http://www.betaparticle.com/articles/articlesDetail.asp?id=55
Any suggestions on batch processing? Every time, I get the error "Illegal Stream Format".
Thanks.
Thread: AudioVCD batch problem
Cool Template. Was wondering when someone would do this. In answer to your Batch encoding question...TMPGEnc has a batch encoding feature built in. I just used it to convert some wav files to audio VCD. What you do is after loading the AudioVCD template, you load the wav file then click 'File/Batch Encode' and select MPEG. After you do this, a box appears showing that the file has been added. Close this window with the 'x' at the top right corner of the box and follow these steps for each wav file you have. When you get to the last one, instead of clicking the 'x' to close the box, click run. If I knew how to import a list file I'd do that instead. Ah well, this way worked for me. If someone knows how to generate a list file that can be imported into TMPGEnc, please let us know. Thanks.
Smabbage
Is there a problem with the batch downloading feature for streamtransport?
By yoda313 in forum Video Streaming DownloadingReplies: 2Last Post: 26th Mar 2011, 07:43 -
Batch file
By Anurag in forum ComputerReplies: 16Last Post: 19th May 2009, 12:27 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 01:00 -
Problem with BeSweet/BeLight. Trying to batch convert Ogg Vorbis to ac3.
By rayden54 in forum AudioReplies: 9Last Post: 30th Dec 2008, 19:37 -
Slight problem when hardsubbing in a batch
By bmwracer in forum Video ConversionReplies: 1Last Post: 25th Jun 2007, 18:32
