I work for a company that has regional broadcast components across the U.S. Most of us use final cut but one component on the west coast refuses to switch from premiere. I haven't used premiere in years and was curious if you could output an apple dv stream file from premiere. Any advice would rock. Thanks.
Hi JoNuggs,
Welcome to the forums.
I use Premiere Pro (v1.5.1) and it can certainly export to DV AVI which, I believe, is compatible with Final Cut. I've had a look in the export options and can't see anything that resembles Apple DV Stream. That said, it might be because I haven't got any particular add-in or codec that may be required.
Search or post in the forums at www.wrigleyvideo.com/videotutorial as the guys there are, among other apps, big time Premiere users.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Apple *.dv is a "raw" DV stream in a format as sent on IEEE-1394.
Windows DirectShow (Premiere Pro) uses DV in an AVI wrapper.
The issue was discussed in this somewhat confusing thread. Several conversion strategies were discussed. Quicktime Pro for Windows may be the solution.
https://forum.videohelp.com/topic331833-60.html
Is Sony Vegas above Apple Final Cut Pro?
By HoosierGuy in forum EditingReplies: 16Last Post: 8th Jan 2012, 00:41 -
Cannon Mv5i and apple pro
By cashley in forum Newbie / General discussionsReplies: 2Last Post: 8th Dec 2010, 15:01 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
Premiere Pro "direct stream copy"?
By Colmino in forum Newbie / General discussionsReplies: 4Last Post: 9th May 2008, 11:31 -
Is Apple pro and regular laptop the same ????
By mol3000 in forum Off topicReplies: 6Last Post: 21st Aug 2007, 18:43
