I recorded a dance at a childrens dance recital. I recorded straight to DVD. Now, I want to edit the recording and don't know how to capture to my editing program (Adobe Premiere Pro). How do I do this? Or is there another way to edit this show?
Do this:
http://digitalfaq.com/dvdguides/edit/dvdrecorder/recorderedit.htm
That should give you a good head start. Premiere Pro will import MPEG-2 just fine.Want my help? Ask here! (not via PM!)
Thank you, Lordsmurf, I gave that a try. I already had the program and used it but it only gave me a VOB again. I already had that from using DVD Shrink previously to make several copies. I tried the Womble software and it's impressive, however, I got an idea to check my WINAVI program and sure enough, it has a VOB to AVI feature. It worked, I got my edit into Premiere and the job is done.
Thanks for kickstarting my brain.
-tepeco -
A VOB, in this instance*, is nothing more than an MPEG. Just rename the file from FILENAME.VOB to FILENAME.MPG.
WinAVI is awful quality. You'd do best to do what I said. If you want to create an AVI for editing, open the MPEG in VirtualDub Mod and then save to uncompressed AVI.
* This ONLY applies to certain situations, usually DVD recorders and DVD cameras, not DVD releases or homemade DVD authors.Want my help? Ask here! (not via PM!)
Finished DVD in Premiere CS5 - transcode in Encore?
By Mylo in forum Authoring (DVD)Replies: 4Last Post: 23rd Feb 2011, 07:55 -
Want dvd to repeat when finished
By wauzoo in forum Authoring (DVD)Replies: 2Last Post: 26th Apr 2010, 07:53 -
Lipsync problem with finished DVD
By Ewen in forum Newbie / General discussionsReplies: 7Last Post: 15th Mar 2010, 16:50 -
Finished DVD pauses for a second every 30 seconds
By shamrockbar in forum DVD & Blu-ray RecordersReplies: 9Last Post: 19th Mar 2008, 12:19 -
HD DVD finished
By videopoo in forum Latest Video NewsReplies: 31Last Post: 16th Feb 2008, 10:01
