I have a DVD movie (.vob files) with DTS sound only. It'll play on my computers fine, but I'd like to redo it so I can also play it on my regular DVD player attached to my gimp TV.
Is there a way to easily do that (or even not so easily if good instructions)? And of course keep the sound in sync? I always have terrible luck with having sound out of sync when I try things like this. Even convert it all to .avi would be fine if one of the converters will handle the DTS sound and convert it. I tried Xilisoft's DVD Ripper Plat and it turned out without any sound.
Thanks for any advice.
How to convert AC3 True-HD to DTS ?
By Kernell in forum AudioReplies: 15Last Post: 29th May 2016, 22:42 -
Convert BD audio from DTS-HD to Dolby 5.1 AC3 without video?
By agent154 in forum AudioReplies: 1Last Post: 5th Apr 2012, 18:19 -
How to convert AC3 to DTS
By lhockann in forum AudioReplies: 8Last Post: 3rd Jan 2012, 08:31 -
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 09:17 -
Easy way to extract audio (DTS) from a .m2ts stream and convert it to AC3?
By marklight in forum AudioReplies: 1Last Post: 8th Sep 2008, 18:42
