I would like to burn some folders with data onto a CD or DVD. I would also like to password protect access to the entire CD or DVD. I am using Nero 6.3 to burn.
Is there a way to password protect the entire CD/DVD with Nero?
Thanks in advance...
I guess you really don't read this board much... It's all about copying cd's and dvd's that you own
(that are copy protected)... If the big studios can't stop it.. you can't either
the answer would be a NO.. you can't stop them from reading the data -
If they are just data files and not video then you could possibly use winzip or winrar and put them in a zip file that needs a password to be opened.
What We Do In Life, Echoes In Eternity.... -
I guess you really don't read post's to well
He's not talking about copy protecting a dvd video....
You could always rar, zip, ect the files up, password protect the rar, zip, ect files then burn those to a cd or dvd.
I'm sure i've seen other way's but i don't pay much attention as i've never really had to protect something that bad or i just did not leave it lying around for anybody to pick up and put in a drive to see what was on it 8) -
Short answer - you cannot do this through Nero, and you cannot password protect an audio CD or DVD Video and have it play in any standard device.
Long answer is that for data you have a few different options.
The simplest has already been suggested. All archive programs now support at least basic encryption and password protection. RAR is probably the strongest and hardest to break. You can compress everything into one big archive, or several smaller ones.
There are also programs that will allow to encrypt and decrypt data on the fly. Mostly this is for HDDs, but some support CD/DVD data as well under certain circumstances. The downside with this is you have to have the software installed on all PCs that the discs will be accessed from.Read my blog here.
Password protect my uploaded videos
By Maurice123 in forum Video Streaming DownloadingReplies: 7Last Post: 12th Oct 2009, 16:40 -
Add password for my own DVD?
By minidv2dvd in forum Authoring (DVD)Replies: 4Last Post: 8th Sep 2008, 23:42 -
How do I copy protect a dvd?
By goheadtry in forum Newbie / General discussionsReplies: 5Last Post: 2nd Dec 2007, 17:22 -
password protect movies
By hackerzlab in forum Newbie / General discussionsReplies: 9Last Post: 31st Oct 2007, 10:47 -
Screensaver Password Protect Feature Not Working!
By lapetite_66 in forum Newbie / General discussionsReplies: 3Last Post: 17th May 2007, 13:57
