Hi,
I have a HP Compaq nx6110 laptop which doesn't have a tv-out. I recently bought an Samsung LCD TV - LE27S7. I also bought a D-sub cable and I tried to connect them, but on my TV it says "No Signal". I tried to set the resolution on the laptop, but no result. Can somebody help me by telling me what might be the problem? How can I connect my laptop with my tv?
Cheers,
Aneta
You'll probably have to switch displays on the laptop. Most laptops with a D-sub socket will have a means of routing the screen to the built in display, an external display or both. I have a Fujitsu Lifebook and to do as you are trying to do I have to connect to the TV, select the correct input (which then gives me the same No Signal message) and then switch the display on the laptop.
On mine it is Function F10, yours will be similar if not the same. Each time I hold down the Function key and press F10, it switches from laptop display to TV to both and then back to laptop display again.
Connecting Analogue hd lcd tv to freesat
By keats in forum Newbie / General discussionsReplies: 0Last Post: 26th Jun 2009, 12:30 -
Connecting an lcd to a comcast tv box?
By Gplracer in forum DVB / IPTVReplies: 0Last Post: 10th Aug 2008, 20:58 -
connecting my laptop to my plasma and lcd
By krisyrfc in forum Newbie / General discussionsReplies: 2Last Post: 19th Jan 2008, 13:23 -
Problem in connecting laptop to Sony LCD TV (KDL-52XBR3)
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2007, 13:31 -
Connecting my MacBook Pro to an LG LCD TV.
By JustSomeGuy in forum ComputerReplies: 0Last Post: 2nd Sep 2007, 20:30
